Old 06-12-2016, 03:24 PM   #20
Nine8Six
Nine8Six's Avatar
I take it you've seen better days. Wanted to cheer up but failed after reading your washing machine werks.
I meant both the ignition switch and the light switch while at it. Get the light switch clean first and literally change the ignition switch if you can. Normally (I'm not a pro) any gizmo flashing or acting up is in most cases related to the ignition switch - or a bad battery.
Also voltage regulator at load (>14.5v?) few things to check. Not fun I know :/
RE your Amazonian charging device... man that's a resuscitation kit. The advert says "1800 Peak Amps"... sure would work for a heart attack lolll. Don't know mate. I'd just take the car battery 12vdc source if you got nothing else. Needs a constant-voltage DC PSU (preferably 12v) with 5~6amp rating min so if this resuscitation kit reads in the manual that you can do it then just use that.
