Old 06-10-2016, 03:49 PM   #5
thom4782
thom4782's Avatar
As others have said, the answer is yes. You need to be concerned, however, about overfilling the low pressure side. If you do, the A/C output temperature will actually go up. And if you overfill it by a lot, it may even cause a component to fail.
BTW: Because I'm not as handy as Meir and I didn't want to drop a couple of thousand on the repair, I did add a Red Angel AC Stop Leak to my system four years ago. Now I just top things off about every 18 months. It's works differently than the ones that swell O-rings. If the leak is too big, nothing will help except replacing the failed component.
