Old 06-07-2016, 05:34 PM   #1
johnsjmc
Originally Posted by Ben006 View Post
It's a tight place, but you should be able to remove them alone.
Get new injector seals and install them even if the old ones look good!
And don't forget to bleed the fuel pressure
I pulled one out and changed a leaking inlet oring now no leak but engine is only running on 5 cyl Could air need bleeding?
johnsjmc is offline   Reply With Quote
