Old 06-02-2016, 02:39 PM   #6
SilverSSS
What year/model is your Boxster?
The 03/04 top is a drop in fit on my 2001. I think with certain early years there may have been more work involved.
There are only 4 bolts holding the top in place.
You simply remove them, pull out the old top, put the new one in place, tighten the 4 bolts slightly, adjust the alignment a bit and tighten them down. Then plugin the window heater cable to the existing connector and your done.
Took no more than 90 minutes including removing the old top, aligning, plugging in the defroster cable etc.
Here is the detail info i used, it will tell you what you need to know.
https://sites.google.com/site/mikefocke2/installinga%2703-%2704glasstopandframeona%2797
This was my question, there was a top i located already from an '04. I have a '01 like yours, simple drop in plug and play?, no dirty mods?, say Yea!..
SilverSSS is offline   Reply With Quote
