Old 05-31-2016, 03:34 PM   #19
911monty
911monty's Avatar
Hadn't heard this. Do you have a link or something that you can forward? If true, then I need to replace everything because its all over the underside of the car!
Tom sorry I've been out a while. Looks like Steved0X took care of you though. Pentosin CHF11 contains a high percentage of Petroleum distillates. You can see on the product list on the can.You can search but in short these are in the gasoline range of the petroleum stream and contain a high percentage of solvents. These solvents are extremely aggressive toward rubber and will soften them to the point they will no longer withstand pressure. Not a lot you're going to be able to do at this point since it is now in the rubber of the hoses, but at minimum spray some Simple Green, soak and rinse off. Or better yet replace those hoses and check the belt. Good Luck my Friend.
