Old 05-30-2016, 11:47 PM   #22
SilverSSS
Just cleaned mine. I highly recommend anybody undertaking this REMOVE the throttle body, the tube it's bolted to and it's sister vacuum tube right above it, and thoroughly clean them with rags, Remove the TB and clean it out thoroughly with carb cleaner and rags. Spraying some Carb cleaner on the the face of it, then putting everything back together isn't really cleaning it. It's a breeze to remove, and the gasket was fine for re-use. Watch that little plastic tube that's inserted into the rear crossover connector, put some oil on it when reinserting it to prevent it from breaking.
SilverSSS is offline   Reply With Quote
