Old 06-19-2006, 11:17 PM   #2
MNBoxster
Hi,
Economics aside, the horror stories stated here are exactly why I prefer to do my own work - I know it's done right!
Good Job on the Brakes, but I have to say that if you are not experienced, you need to have someone who knows assist you the first time. Also, you need to pay attention to properly lubing the brake hardware to insure a Caliper doesn't stick.
Also measure your rotor thickness to make certain that you're within spec. Typically, these rotors will go through two sets of pads and then they need replacing. This wear is accelerated with the use of more agressive Track or Street/Track pads. Failure to do so will cause the pistons to expand too much and corrode which then acts to prematurely wear the seals requiring rebuild/replacement of the calipers.
Runout should also be checked as well for maximum Braking efficiency and Pad wear. Failure to do these checks can be just as bad as not having the wheels properly torqued. You do it while you're in there because you're not in there every week, month or even year.
Changing Pads, while not Brain Surgery, is still Surgery and a certain amount of know-how is necessary to insure that both you, and the people you share the road with, remain safe...
Happy Motoring!... Jim'99
