Thread: Still learning
Old 05-26-2016, 02:47 AM   #1
Jamesp
Beginner
Jamesp's Avatar
Replacing O2 sensors idseasy, and used from Woody should work. To make sure the sensors are toast you could look at the sensor output which requires a tool such as the Durametric, but simply replacing the sensors should suffice. You can google the codes to determine exactly which sensor needs replacement.
2003 S manual
