Old 05-19-2016, 04:22 AM   #6
Muskoka Minute
Muskoka Minute's Avatar
Originally Posted by B6T View Post
I think your car has the CDR-23 head unit which is connected to the factory amp via a fiber optic cable. This prevents connection between the aftermarket HU and the amp via a wiring adapter.
You'll likely have to install an aftermarket 5-channel (?) amplifier as well, and then wire that to the factory speakers.
So you think I will have to change the wire to the amp and the amp itself.
Will I have to change the wire to the speakers also or will that wire be ok?
My Beast 2004 Boxster SE #0174
- 3.8 with all the internal goodies, Under-mount Pulley, IPD Plenum, 996 Intake, Softronic Tune, 987 Factory Sport Exhaust, skid plates, IMS solution, Ohlins R&T, RSS Toe Links, Camber Plates, Michelin Pilot Super Sport on all 4 corners, Alpine Double Din c/w new speakers & amps.
Muskoka Minute is offline   Reply With Quote
