Thread
Brake Booster Replacement Problem
05-16-2016, 01:16 PM
2
nicolas061291
Originally Posted by
Need_for_speed
Nicolas, my understanding is that the design of the brake booster was changed in 2002 to incorporate a bellows on the booster to keep out water. Consequently, the old style booster was no longer available from that point on. In order for the new booster to work properly, there were other parts that need to be changed. Here's the link to the TSB:
http://www.pelicanparts.com/techarticles/Boxster_Tech/57-BRAKES-Booster-ABS/TechBulletin.pdf
Thanks for the reply.
Where do I find the mentioned VIN? Is it the same as the one you use on Carfax or something else?
This could be a reason. Shouldn't the mechanic be aware of it?
Best,
Nicolas
nicolas061291
Find More Posts by nicolas061291
