Old 05-15-2016, 01:10 PM   #1
Smallblock454
Hello,
your car has to stand on leveled ground. Else the display results will be wrong. And if you take a look in your user manual, Porsche also recommends to use the dip stick. But also the dip stick will only give am exact result if the car is on leveled ground. So only check oil level on leveled ground.
Regards, Markus
