Old 05-15-2016, 09:19 AM   #11
johnsjmc
If the tag is missing you might be able to obtain the original build specs from a dealer with your vin number. If aftermarket lowering springs they will likely be labelled on the springs H&R are typically painted red .Eibach are usually black. Factory springs will have coloured paint dabs on them which can give a clue to specs. If the car has the factory m030 sport suspension the euro (ROW) version is about 15 mm lower than a regular car and will also have thicker sway bars a rear bar for a standard car with sport suspension will be fat 19.7 mm diameter.
johnsjmc is offline   Reply With Quote
