Thread: Help!?
Old 06-17-2006, 12:45 AM   #3
specivic
Originally Posted by blinkwatt
Nevermind false alarm,I got it. But another problem occured, one of the four main bolt connecting the throttle body to the intake manifold snapped in half as I was loosing it. Part of the bolt is still inside the spot where it can from in the manifold,can this cause any issues? I started up the car and let it run for 10 minutes with the three other bolts nice and tight with no problems.
now I am no porsche expert but I know w/ hondas if u left it like that, u would eventually get leakage from the TB...Hence, hindering the clean flow of air into your Intake Manifold. to get the bolt out: spray it w/ pb blaster and then try using a screw extractor on it. Depending on how bad the bolt is lodged in there, pb blaster might not be required but that is what I spray every bolt/screw w/ on the ext of my car prior to making any attempt at unbolting/unsrewing anything.
specivic is offline   Reply With Quote
