Old 05-08-2016, 12:34 PM   #30
Akjoe
Originally Posted by reiver View Post
I want to replace them all while I'm there as I have a leak with at least one of the worn seals. The window doesn't press against the seal enough to keep the rain out (while parked) as the seal has gone a bit flat. I'm not a fan of having to redo my carpet after it getting soaked. :troll:
I believe you can adjust the camber of the window and perhaps improve the seal you're having trouble with. Search through threads here on replacing your window regulator. Not that you need to replace the regulator, but adjusting the window angle and seal are discussed. Might keep the rain out without a full seal replacement.
Akjoe is offline   Reply With Quote
