Old 05-03-2016, 01:30 PM   #11
Ben006
Ben-Auto-Design
Ben006's Avatar
Hi!
The PelicanParts DIY is quite good, you should be able to do it.
Porsche Boxster Short Shift Kit (SSK) Installation and Shift Bushing Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Here are some quick tips:
Originally Posted by Ben006 View Post
few tips:
-To remove the center console, it's better it the hand brake is a bit loose: it has to go high. You can also engage the 4th gear, you'll have more room to remove it.
-Get that: SureBilt/4 pcs. seal and O-Ring remover set 82030 - Read Reviews on SureBilt #82030
It can be used to remove the lower section of the mid console, pry the shift boot and access the screw hidden under the coin holder!
Trust me, it will save you a LOT of time!
-Use zip ties to mark the position of the cables in their holders, and use bigger zip ties to hold the spring compressed when you put the cable back in:
We have almost reach the minimum amount of people to start
Ben.
The worst part is getting the center console off if your handbrake doesn't go high. After that, it's easy.
Also, don't tighten the big set screws hard, just by hand until there is no play, then lock them with the nut
Ben
ASE certified Automotive Master Technician.
Porsche Tech in France.
www.benautodesign.fr
Ben-Auto-Design : Performance parts for 9X6 / 9X7
1982 928 S Euro
Ben006 is offline   Reply With Quote
