Old 04-30-2016, 01:07 PM   #1
Deadeye
At the track you can lower the tire pressures a little in the rear and add a little to the fronts.
If you have adjustable sways, try a little softer in the rear, then if that doesn't fix it, stiffen the fronts.
if you did not have the car corner balanced after the struts were installed you need to do this to get the car at least close to balanced before any other adjustments
Deadeye is offline   Reply With Quote
