Old 04-29-2016, 07:37 AM   #11
GTsilber
Here is a list of maintenance items that I plan on completing in the next couple of weeks:
1. Clean Throttle Body (complete)
2. Replace spark plugs (went with OEM Beru)
3. Oil Change (going with Pentosin 5w40, Hengst filter, new LN magnetic drain plug)
4. Inspect existing oil filter for metal/plastic
5. Replace driver side door check hinge
6. Replace fuel line vent valve (ordered OEM off a 2002 911)
7. Replace AOS (OEM part purchased)
8. Check brake wear sensors - (dash light is illuminated but pads look good)
9. Possibly replace B1S2 o2 sensor
Anything else I should be looking at, other than IMS?
GTsilber is offline   Reply With Quote
