Old 04-25-2016, 05:08 AM   #14
boxxster
Originally Posted by redeye280z View Post
I've tried wd 40 , varsol, gas, kerosene,a couple of commercial bug and tar removal products and nothing has worked. The tar is really hardened and nothing seems to soften it up. I don't want to ruin the paint with I am at a loss.
Varsol should work. I just removed a ton of tar from my wheels and back bumper with it. Here's what you do. Get an old rag and lightly soak it with a bit of varsol. Then use it to wet the affected area and let it sit for a couple minutes. After a couple minutes, gently rub the area with the damp rag using a gentle circular motion. The key is to keep the tar wet with varsol while gently rubbing at it with the rag. Keep the rag adequately saturated with varsol and gently rub at the tar until it comes off. This make take a few minutes of gentle rubbing but it should all come off. Varsol will not hurt your paint, although it's good practice to hose the area down and apply a nice coat of wax afterwards.
