Old 04-23-2016, 04:40 PM   #11
GTsilber
I have been trying to trouble shoot my top issue, so far no luck. Here are some things I tried and observations:
1. Check handbrake is illuminated in dash when pulled - confirmed
2. Check top microswitch is working correctly - when pulled Windows go down, when pushed up windows roll up - confirmed
3. Remove top double relay and reinsert - confirmed but not sure if relay is bad?
4. Replace B6 fuse - confirmed
5. The top warning light does not illuminate when placing key in ignition, not sure if it should
6. The top rocker switch does not illuminate with yellow light, upon toggling switch no sound from top motor or otherwise
What else can I try?
On another note, got a CEL light, P0420. Hooked up my OBD2 and noticed that B1S1 and B1S2 are showing similar voltage, do I need to replace S1 or is it the cat that's bad?
GTsilber is offline   Reply With Quote
