Old 04-22-2016, 05:28 PM   #13
Sassmatt72
that's not what I meant to convey (not what I said)
the seal is fine, at sealing in the original dose of grease, for ever.
the lube, "from the factory", gets cooked into slime, then the bearing fails...
the problem is no other bearing inside a motor is sealed like this under such load.
ever other bearing is directly oil fed, or in a splash or submergence zone.
M
Sassmatt72 is offline   Reply With Quote
