Old 04-21-2016, 07:22 AM   #7
rick3000
There Is No Substitute.
rick3000's Avatar
Originally Posted by Ben006 View Post
Depends on the quality of water where you live.
Tap water can cause scale and electrolysis.
Distillied water is 64cts a gallon, it's worth it
This is 100% correct. Two gallons is just under half the entire coolant system, so I would drain the system, flush with a lot of distilled water and replace the coolant with the correct 50/50 mix.
