Old 04-20-2016, 06:45 AM   #19
rem503
Diy
I started off knowing nothing about the 2000 base Porsche Boxster we purchased in 2012. I have since, thru the Bentley manual and help on this site and others, learned a great deal and have accomplished a lot. This is such a helpful site.
First thing I did was change the oil then in no particular order...
cleaned throttle body
bled brakes
replaced headlight bulbs
replaced accesory belt
replaced fuel filter
added void to dash
replaced spark plugs and 'o' rings
replaced cigarette lighter with two power ports in dash
tightened loose steering wheel
cleaned radiators and added center radiator
flushed power steering fluid and insulated hose near exhaust
replaced two idler pulleys
upgraded to 's' oil cooler
replaced water pump
replaced AOS
replaced all the rubber coolant hoses
replaced MAF
bled clutch
replaced rear oil fill tube (ugh)
replaced ignition key switch
rem503 is offline   Reply With Quote
