Old 04-18-2016, 06:59 AM   #2
Luv2Box
Luv2Box's Avatar
The "emergency" release cable is in the front passenger side wheel well under the liner. You'll probably have to remove the tire to unscrew and remove the liner. Once you access the cable and get the frunk open reroute the cable so it comes out the tow hook hole so if there is a next time it is easy to access and pull straight out on. You'll probably want to replace the locking mechanism, which is mechanical (no solenoid).
Luv2Box is offline   Reply With Quote
