Old 04-09-2016, 09:51 PM   #4
Meir
1999 base
Meir's Avatar
this is the setup for installing the new bearing.
the setup of the tool is very similar to the removing setup, but part #14 is replaced by the installation washer and the orientation of the tool is reversed.
this is how it looks from the front
and this is from the back
before i started wrenching, i made sure the bearing is totally squarer with the bearing housing.
i took the bearing out of the freezer and lightly taped it with a rubber mallet, before i put the tool over it, so basically the bearing was slightly inserted, and hanging by itself in the housing.
i made sure the plate is touching the housing, and the bearing is totally inserted and flush with the surface.
