Thread: Exhaust sytems
Old 04-09-2016, 07:59 AM   #11
Need_for_speed
Originally Posted by Chuck W. View Post
I installed the TopSpeed Cat Delete pipes. They were $160 shipped from TopSpeed. It improved the sound (IMHO) but still is not as good as the FDMs. The install was easy but I have heard that the cat delete pipes could cause heat issues to the drive shaft rubber boots.
I am not sure what you did when you "welded open" the PSEs. The default to the valve is open... the louder position. If you welded the valve open you may have set them to the quieter position.
Chuck, By drive boots you mean the rubber cv boots, right? Haven't heard this before. Do the deletes take a different path closer to the boots? Do they get hotter than the secondary cats?
Need_for_speed is offline   Reply With Quote
