Thread: Exhaust sytems
Old 04-08-2016, 08:46 PM   #11
thatguychad
Originally Posted by Chuck W. View Post
I am not sure what you did when you "welded open" the PSEs. The default to the valve is open... the louder position. If you welded the valve open you may have set them to the quieter position.
The previous owner had the exhaust installed and it was welded when I got it. There were no vacuum-actuated valves installed, so if the weld was removed (which we did), the valve freely moved (and quite easily.)
The reason I removed the weld, initially, was because there was a rattle internal to the exhaust. We removed it, played with the valve to determine the "loud" setting, then put a little spot weld to hold it in that position.
thatguychad is offline   Reply With Quote
