Old 04-07-2016, 06:45 PM   #10
particlewave
Originally Posted by ltusler View Post
Other than it seems you have an ax to grind and don't know what you're talking about as JFP showed.
Being an engineer, I know exactly what I'm talking about.
My point is that I've watched 3 rebuilds in which JR and your fellow fanboys said that it wouldn't work due to failed bearing debris. All 3 are still running. If caught early through due diligence and proper filter/magnet check (or with the Guardian), and with proper tear down and cleaning, the engine is completely salvageable. It just takes a competent and willing person.
The Guardian may not have "been designed" for the 986, but it sure is marketed as such and plenty of 986/996 owners use them for that exact reason.
Now, I've read rennlist for years and am very familiar with your posts. I've witnessed you attacking some that question JR, resorting to name calling and accusations like, "I bet you don't even have a Porsche". I will not debate technical details with someone that has exhibited both zero technical background and the propensity to start hurling insults when his weak argument with no actual technical basis breaks down in the face of intelligence.
So...I'm just going to add you to my very short block list. The 986forum is better without that type of behavior.
Have a nice day!
Last edited by particlewave; 04-07-2016 at 10:57 PM. Reason: not worth the keystrokes. ;)
