Thread: Exhaust sytems
Old 04-05-2016, 04:05 PM   #2
Luv2Box
Luv2Box's Avatar
Originally Posted by glenf View Post
Thanks for that info. I cant seem to find any soundclips other then the "S" version
I have the Base 986
do you think it will sound significantly different then "S"
also what do you mean by drone? appreciate the feedback
Drone is the harmonics created by the exhaust valves that becomes more noticeable as the exhaust header material gets thinner. Most, if not all, aftermarket headers are made from thinner metal, usually aluminum, so they will have some degree of drone. You've probably noticed the OEM headers on your Box look like they came out of a Soviet submarine they are so thick and clunky looking but work very well and don't have drone. I've got the Fabspeed on my '99 and there is drone around 2.5K rpm but when it hits 3K rpm the exhaust note is a symphony. It is hard to describe drone you really have to hear it and it does drive some people crazy. Find a sound byte of it before you change out your headers so you know if you can handle it and buy a good set of headers that have a splitter in the junction box, smooth bends and cleaned up welds especially at the flange openings.
Luv2Box is offline   Reply With Quote
