Old 04-04-2016, 12:31 PM   #1
PorscheFan5
Originally Posted by Sassmatt72 View Post
well, I got as far as webbing and all, kinda worked, but not near good enuf...
did you know (as I do now after 2 pick&pull yards) the latch actuation cable from latch (striker) to lever (on inside) is an Audi part...
so the same striker end cable is attached to almost any vw and audi inside lever...
A4 rear seat pulls (w tweeter), and it's cable to lock, perfect fit into boxster latch...
and clean and flat... Now to mount the micro-switch, cut Another pannel...
off to the salt mines.
Matt,
Do you happen to know the Audi PN or the model of Audi that uses it? I am talking about the white (about 6" long) white rear trunk actuator cable that releases the trunk when the button in the car is actuated... I think I can replace just the white cable part...
Thanks.
PorscheFan5 is offline   Reply With Quote
