Old 06-12-2006, 11:58 AM   #23
rodsnhawgs
One of the things that has puzzled me about a "performance" car such as the Boxster is the lack of an oil pressure (O/P) gauge. That being said, has any of the "mechanics" checked the O/P? There are lots of things that will squeal (alternator, A/C compressor, water pump, etc) not to mention the belt. "Ticking" could be an O/P related problem and/or something internal. Remove the belt that drives the above components - does the squeal go away? Does the ticking go away? If it does, you can concentrate your search on one of them. Assuming it does not... do you have good O/P? Can you get the car on a lift? If so, use a long-handled shaft (i.e., screwdriver, etc.), place one end tight against your ear and probe the engine w/ the other - you can hear most everything going on inside. This should get you to an area close to the source of the ticking. Do this on top and from below.
Re a replacement engine (worst case senario), I would search for a salvage yard piece. My guess is that would save you thousands. These cars are not brain surgery so let's not get all "anal" about them - they are, in the end, an internal combustion engined automobile. Although Porsche has done a relatively poor job of designing/fixing the RMS problem, other than that, it seems to me they should be capable of doing daily service for 100K miles+ without anything but regular maintenance. What else would anyone expect out of a $50K car??.... I'll look forward to your report.
02 boxster
chopped 48 Chev pickup (under construction)
99 Harley Road King
04 Honda Element
07 Nissan Murano
rodsnhawgs is offline   Reply With Quote
