Old 03-30-2016, 05:26 PM   #1
Enginuity
Guest
Posts: n/a
Dan,
Keep up the fabrication work.
My 986 GTS-R (Techart 997TT GTS influenced) wide-body is under body coachwork fabrication and wanted to ask you if you had 19" or 20" wheels on your car?
I read numerous posts in forums that mentioned 20" wheels would be a horrible ride performance and feel on a 986, yet a owner in Canada said that his ride performance and feel were un-expectingly good. I can make them fit but a but worried about how it will perform and ride, and don't want to go smaller than 35 series in the front and 30 series in the rear.
Currently, I'm planning on going with 19x8.5 by 19x13.5 wheels. I may or may not go a half inch wide in the front, it depends on the available tire sizes. All the exterior work should be done around this coming May.
By the way, what are you cruising in now? Be sure to keep in touch.
Cheers, MoMo
contactmomo AT gmail DOTcom
SS Motorsports, Walnut Creek, CA
