Originally Posted by dghii
Ok. Just put the top in service position, remove tension cables to allow the rear window to be raised up. You should have good access to dig that rod out.
Get a helper to raise/lower the top a bit to help you get access and alo to connect the rod when you do get it free.
Thanks, will try. The rod is wedged in the cavity left and below the ball in the photo below. You can barely see the transmission arm and the connected rod. The rod is positioned towards the front of the car. Tightly wedged.
2001 Boxster S: Triple Black, Sport Package, Special Chasis Rigidly Tuned, Headlight Washers, Turbo Wheels, Litronics, Full Leather, 03 Top, Sumitomo HTR ZIII, IMS/RMS, Kenwood KDC-BT562U, DEPO Tails, Cocomats, KUDA Cellphone Holder, Ultimate Cupholders, Zaino Shine
PCA-MAGNOLIA
