Old 06-11-2006, 02:44 PM   #3
PorscheDoc
Major Service at 90k
Read out DTC Codes
Check Polyrib belt
Change oil and filter
Replace spark plugs
Visual inspections to engine (oil leaks, fluid leaks, coolant hoses, etc)
Replace air filter
Replace cabin filter
Check all fluid levels (brake. power steering, etc)
Check parking brake
Check pads and rotors for wear
Brake hoses and lines inspection
Check clutch play and pedal end position
Check throttle actuation
Visual inspection of steering gear, tie rod ends, etc
Inspect play in CV axles
Inspect exhaust system
Tire and spare inspection for wear
Check doors, locks, safety releases for proper operation
Check vehicle lighting
Washer fluid and windshield wiper inspections
Test drive.
There are a few things I left out, but most were visual inspections of systems etc.
Karl Wilen
RennsportKC
PorscheDoc is offline   Reply With Quote
