Old 03-24-2016, 12:57 PM   #2
911monty
911monty's Avatar
Originally Posted by Krieger View Post
How do you do this? am not a computer wizard, but I could figure this out with some help. I am having the same problems connects to engine, but not airbag?
Krieger: If your Durametric cable is able to auto select your DME then your .Net framework version is likely fine. Basically this is language that allows the application to run. Do you have a seatbelt fault? I believe this would prevent access to the airbag.
