Old 03-24-2016, 09:43 AM   #1
2ndtimearound
March 2016 - Any updates or identified causes
I'm having nearly the same issue on my '99 boxster. No water, blown fuses, etc.
In fact, a great independent shop here has replaced the ABS controller x 2 only to have the problem repeat. Alternator and speed sensors both test ok.
Any ideas? We are at a total loss.
Of note, the problem appeared upon engine restart. In other words, it worked fine. Car was turned off, then ABS light and no speedometer (electronic or guage). The rear trunk light comes on at the same time.
The brake light has never come on when this problem occurs; however, I can confirm that the light does function as it does illuminate at test/ignition on.
Many thanks!
2ndtimearound is offline   Reply With Quote
