Old 03-21-2016, 05:36 AM   #18
bulldogge01
bulldogge01's Avatar
Updated parts list
- Rennline pedal cover set (3 pieces; pedal, brake, clutch). I started to install this and got irritated. This is the set without the rubber pins. I barely hit inside of one of the holes with a drill (I don't think you will even notice it but being up front about it and if you use the same mount point the screw head will cover it). $120
- OEM Four Spoke Steering wheel and airbag $250 (near perfect condition)
- OEM Tail Light Housings (986.631.443.02 and 986.631.444.02) pair (housings only no electronics) $120
- Becker CDR-220 face plate case $5
- Set of 4 OEM Silver center wheel caps 993.361.303.05 $70
- Center console power window switch trim (no buttons or dead switches) 996.552.095 $15
- The leather zippered storage bag/compartment for rear deck. Not sure about P/N on this. I also have the bracket that you need to rivet to the rollbar. I am missing one of the screw plugs to attach to deck, but it never moved in my car even with only one plug installed. You can probably get a replacement for a few bucks. $70
- Rear storage deck box (this is the hard shell one). Black carpet. $100
- Pair (996.631.037.01 and 996.631.038.01) orange side markers w/ bulbs $30
bulldogge01 is offline   Reply With Quote
