Old 03-09-2016, 08:03 AM   #14
trygve
That should work for the spoiler, and is a common solution. You should get rid of the cross bracket that holds the motor. I can't recall for sure if there are feet that help bolt the tubes to the floor on each side for stability. Maybe that's what's bolted to your cross bracket at the bottom left corner of your photo -- remove it from the bracket and put it back on the tube, bolted to the floor.
trygve is offline   Reply With Quote
