Old 03-09-2016, 06:50 AM   #11
tomonomics
Pore diameter in the filter media is restricted by the need for fluid flow. In other words, there are many ferrous metal particles that are small enough to fit through the pores of the filter media and if those pores are made smaller, the oil will not flow freely enough and/or the filter will become clogged by debris prematurely and cause either complete filter bypass or oil starvation.
Magnets in oil filtration systems are actually pretty common, just not on passenger cars.
I've seen them in transmissions, as you're expecting more particles there, but if you've got that much metal in your engine oil, you've got other problems.
Also, while it seems these are crazy strong magnets, I'd still be concerned that oil flow + a large pothole would release a clump of the sludge all at once, which would be more likely to cause a stroke. As opposed to Coumadin (frequent oil changes).
I recall from my Miata days some Blackstone comparisons in oil samples from magnetized filters, but I can't find it. (no pictures, so it didn't happen!)
tomonomics is offline   Reply With Quote
