Old 03-08-2016, 06:58 AM   #1
trj
1997 Spec Boxster
Well sorted 1997 Spec Boxster New Build for Sale. Break in miles only : $32,500 Professionally Rebuilt Engine. LN Engineering IMS update New Aasco lightweight flywheel New Sachs Racing Clutch RSS Lightweight under drive pulley LN Engineering deep sump oil pan and skid plate New radiators ( only side not center ) All new pumps, hoses eat Bilstein PSS9 Coil Over Suspension Swift Upgrade Coil Springs, SPB SPEC 450# & 500# NewTarrett 986 Front Sway Bar & Drop Link Set, 26.8mm 5 POS ADJ Tarrett 986 Rear Sway Bar & Drop Link Set 19.1mm, 4 POS ADJ TarrettRear Toe Link Set 986 GT3 Lower Control Arms Front One set of Porsche 8.5x17 powder coated black. 4 - 7x 17 fronts as well 4 Toyo Proxes RR 255/40R17 Stickers New Sparco seat, OMP steering wheel with Rennline Quick release….. Wheel studs with Nascar style lug nuts Wevo semi solid engine and tranny mounts. Tune RS Custom race exhaust. New Rotors/Padgid Yellow Pads SRF/Redline/Mobil 1 fluids SPA AAAF 4 Liter Mechanical Fire Supression. Rennline lightweight battery/mount and kill switch Lightweight fiberglass top New wheel bearings on all 4 corners New brake booster Car was just built and all race items suspension ect are brand new. This ifs a freshly built never raced car not some beat up race car that needs half of the items rebuilt.
trj is offline   Reply With Quote
