Old 03-07-2016, 04:03 PM   #6
Benitom
1998 Boxster Owner
Originally Posted by winter.k View Post
It's important to notice that the spoiler switch is made for the 996 dash which has horizontal switches. On the 986, of course they will fit, but your switch images will be rotated 45 degrees and might look funny. If you don't care about the pictures, and want to do it on the cheap... you can just get any old switch from the 996/986 and it will work if you wire it up properly. The common ones will be cheaper.
You can also get an indicator light that flashes when going up and down.
Thank you Winter for the suggestion. I will look into the standard switches.
Benitom is offline   Reply With Quote
