Old 03-06-2016, 08:48 AM   #18
jdlmodelt
Originally Posted by tada View Post
Replaced fuel filter (the engineers were so nice to put it in a convenient location). Jumpered the fuel pump relay and heard power going to the fuel pump. Still no good idle or rev. So, got a fuel pressure tester. Gauge is reading 35 psi (2.4 bar) with the engine not running. Currently doing a leak down test and its holding steady at 35 psi. Bad fuel pump?
After 10 minutes, leaked down to 32 psi. Releasing gas cap did not change readings.
Did you see Gilles comment about a bent pin?
