Thread: 3000 rpm
Old 02-27-2016, 05:01 AM   #16
boxxster
It's surprising to me that people are having vibration issues with these engines. It's a pretty well known fact that a flat 6 configuration is inherently balanced, or at least should be in theory. I never cruise at 3k, usually 2500-2800 so I haven't really noticed this on my car.
FWIW, I found this excerpt which was written about a 2001 S in a porsche technical document.
"In operation, the engine control unit operates timing pistons in the intake
camshaft chain tensioners. When the engine reaches 1,200 rpm, the control unit
signals the piston to rotate the intake camshafts by 12.5 degrees. When the
engine reaches 5,120 rpm, the pistons return the camshafts to their normal
positions. The control unit will delay VarioCam until 1,480 rpm if the engine oil
temperature exceeds 266 degrees Fahrenheit (130 degrees Celsius)."
So it looks like the engagement window isn't at 3k, at least not for the 3.2. Interestingly enough, however, the next paragraph says:
"The Boxster S shares its twin-resonance air induction system with the 911
Carrera. The system acts as a “resonance supercharger,” allowing the engine to
draw from higher velocity airflow at certain engine speeds. A crossover pipe
connects the individual air collector/resonance chambers for each cylinder bank.
A flap in the pipe remains closed from idle to about 3,100 rpm. When it opens,
each cylinder bank can draw from airflow “excited” by the resonance created by
alternating induction between all six cylinders. In essence, “dual resonance”
creates two induction paths for each cylinder. Below 3,000 rpm, the cylinders
draw air from a “short” path. From 3,000 rpm to about 5,100 rpm – when the
resonance flap opens – the cylinders draw from a long intake path, which boosts
torque. Above 5,100 rpm, the flap again closes to allow the cylinders to draw
intake air from a shorter intake path to boost horsepower at higher engine speeds"
Total shot in the dark, but I woudn't be that surprised if the vibration when hovering around 3k had at least something to do with the intake paths constantly changing between the long and short paths and the fluctuation of torque it would create.
Source:
http://press.porsche.com/archive/products/press_kits/press_kits_2001/PDF/Boxster_S_in_Depth.pdf p.13
