Old 02-25-2016, 06:21 AM   #3
rick3000
There Is No Substitute.
rick3000's Avatar
I would consider replacing the water pump preventatively, and if you are going to drain the coolant system, you may want to also consider a low temperature thermostat. 90k is more the major service, but I would still check your drive belt and fluids. If you have never had your transmission fluid changed you might consider doing that too.
