Old 02-24-2016, 08:27 PM   #2
Dr Feelgood
Originally Posted by philou320 View Post
Yes I wiggled mine when the blower wasn't runing and it worked, I did that after having pulled everything
out (of course), there is also a resistor located in the fan casing
This has been getting very frustrating. After searching around some more I found some methods of testing the circuit. One of the methods was to check slot 87 of relay 18 which should have battery voltage with the key in the on position. It does not. Also there was a test for the control unit by removing the C connector and testing some pins. Apparently I have some sort of wiring variation and do not have the C or A connector. I scoured the area looking for a connector that may have been disconnected but it just does not exist. Any ideas of where to go from here?
Dr Feelgood is offline   Reply With Quote
