Old 02-21-2016, 01:28 PM   #2
oc-boxster
oc-boxster's Avatar
I got a header cat replacement several months ago on eBay for about $260.
I would also try Woody first (Itsnotanova) as he is an honorable gentleman that can be trusted on this forum and has more than fair prices.
My old cat has lost the cement seal between the cat element and the shell allowing gasses by. You can hear it slide back and forth inside once its removed from the car.
Its an easy repair that does not tale long. Don't forget to order a header and pipe gasket for either end if you DIY.
I have seen what seem to be direct replacement parts on eBay but I don't recognize the brand names, which one did you get? Are they smog legal for CA?
oc-boxster is offline   Reply With Quote
