Old 02-20-2016, 05:47 PM   #14
boxxster
Oh and a question about the headlight issue I was having. When I was driving the car during the day, the drivers side headlight (the projector, specifically) goes out after about 5 minutes. If I turn the car off, then back on again, it will go on for another 5 minutes. This is all with the headlight switch in the off position (I have DRLs). However, when I drove it just now in the dark, I had the switch all the way to the right (which basically just turns the interior lights on in my case) and both lights were still on after a 20min drive. So from what I'm gathering, whether or not that light stays on appears to be related to switch position, even though in my case all turning the switch to the right does is turn the interior lights on. Does this sound like an issue with the headlight switch? Or would an issue with the switch cause both lights to go out? Keep in mind, the light that is giving me trouble is the one that was undamaged, not the one I had to replace.
