Old 02-19-2016, 08:02 AM   #2
apswater
apswater's Avatar
Full instructions.
http://www.pelicanparts.com/techarticles/Boxster_Tech/91-ELEC-turn_signal_switch_-_OBC_upgrade/91-ELEC-turn_signal_switch_-_OBC_upgrade.htm
Dwights terminals are a little larger than the right ones but you can force them in. The ones called out for in the Pelican instructions fit better and can be removed easily if necessary.
You might need a magnifying glass to get the right numbers (there is an app for that) but they should be the open slots.
SciGuy
2000 Boxster S (13K miles)
apswater is offline   Reply With Quote
