Thread: Buyer question
Old 02-18-2016, 08:41 AM   #13
tada
1998 Boxster Owner
I would have made an offer on the first car you posted. An offer low enough that I would expect it to be turned down. Heck, buy the worst one you can find for the lowest you can get it. Tear it apart. Find out what makes it tick ...and then buy one that isn't ticking quite so loudly.
I'm off tomorrow, so I am going to go down and take a look at it. I got access to an iCarsoft POR II (not debating it vs. Durametric, it was available to use for free) and I'm going to check to see what codes it is giving. I'll be looking for the obvious blown head, will watch the tach to maybe test for CPS while cranking it (if it doesn't throw a code), listen for the fuel pump and relay, and just look it over in general. If it looks good, I may take the risk. You saw that I am prepared to work on myself and learn the car. Any other apparent things you all can think to look for in a non runner? Thanks!
tada is offline   Reply With Quote
