Old 06-07-2006, 01:24 PM   #17
creseida
Guest
Posts: n/a
Ok, I do have a suggestion, to at least get confirmation that there might be a problem. Many Tire places, like Tire Kingdom will do a free alignment check for you, and can do a wheel balance for you for a nominal fee, like $30.00. They can also tell you if there is a problem with a tire or wheel, esp if it won't balance without excessive weights being applied. If they find something, you can then take it to your dealer and say, "Ok, I've had an independent 3rd party look the car over and they've found this. Are you going to fix it under warranty or not?"
Just a thought...and one that shouldn't cost you Porsche tech rates to try.
