Old 02-08-2016, 09:48 AM   #7
Gelbster
CV boot/clamp.
Sounds like sloppy work.
These cars are very unforgiving of sloppy work in my experience.
Suggest you check the other boots and clamps. Did they use the correct clamps ?Regular worm drive hose clamps -not good.
It is difficult to get any clamp to work on the CV housing if they did not scrupulously clean off all the grease. It will keep slipping off when the grease gets hot/the shaft travels full motion.
Sounds like you need to find a good Indie?
